1st Sound Port
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=42000
Author:  EddieLee [ Thu Nov 21, 2013 9:34 am ]
Post subject:  1st Sound Port
I am working on installing me 1st sound port. I am wondering what type of designs people normally do. Let's see your sound port pictures. Any tips would be appreciated.
Author:  Doug Balzer [ Thu Nov 21, 2013 9:41 am ]
Post subject:  Re: 1st Sound Port
Paw shaped sound port.
Author:  SteveSmith [ Thu Nov 21, 2013 9:47 am ]
A cross:
Author:  JasonM [ Thu Nov 21, 2013 11:21 am ]
Just a simple oval for me, but folks always seem to think its where electronics will be installed. The fancy shapes take away that impression, although I opt for simplicity, for ease of sanding and finishing.
Author:  EddieLee [ Thu Nov 21, 2013 11:29 am ]
These are all beautiful and very nicely executed. Are your sound ports cut with the use of a jig or cut free hand?
Author:  Chris Ensor [ Thu Nov 21, 2013 12:35 pm ]
Yes.
For ovals, I use a template. This makes it easier to bind if you so choose to as well.
For other shapes like f-holes, crosses, etc. I would cut it free hand.
Author:  SteveSmith [ Thu Nov 21, 2013 2:29 pm ]
I do mine free hand with a laminate trimmer. I do glue a paper pattern on first.
Author:  sdsollod [ Thu Nov 21, 2013 4:12 pm ]
Oval...
Author:  Robbie_McD [ Thu Nov 21, 2013 6:45 pm ]
Freehand with a dremel, then finish with needle files...
Author:  theguitarwhisperer [ Thu Nov 21, 2013 7:44 pm ]
Is there a routing jig that works on a completed box?
Author:  theguitarwhisperer [ Thu Nov 21, 2013 8:19 pm ]
SteveSmith wrote:
A cross:
I'm digging the look on this one.
Author:  EddieLee [ Fri Nov 22, 2013 9:28 am ]
Todd, What do you use to make the cut? Router with a guide ring and a 1/8 bit?
And a thank you to all.
Author:  SteveSmith [ Fri Nov 22, 2013 11:10 am ]
theguitarwhisperer wrote:
SteveSmith wrote:
A cross:
Thanks. I designed that and used it on that rim set then found that PeterM (I think it was) had already done something similar with his guitars - so I can't claim that I originated it.
